brake booster hose
Shane
Ontario, Canada
Heres a real dumb question, but I want to make sure I have it right..
I have a breather on the drivers side Valve cover. I then have one with a tube on the passenger side that hooks up to my air cleaner. Then I have my brake booster line. Should it attach to the back of my carb or the outlet on the back on the drivers side of the intake manifold? And do I just plug the one I dont use??
Thanks
Shane
you can use either one of them, as long as its a full vacuum port. on a holley its usually the one on the pass. side rear or an afb style its the one on the lower rear port. and yes plug the other one you dont use.
