rp23g7
So, my wheel cylinder had been sticking, causing my car to pull to the right, then left as i hit the brakes.
I replaced both front cylinders, and bled them. Before i replaced them, the brakes felt fine, and stopped the car fine.
Well after i replaced them i drove it, and it seemed ok, the next morning we took it to the car show, it took it on the freeway and when it took the exit the brakes were really bad, soft pedal and such.
We got home after the show and i bled them again, got some air out, adjusted them so there was slight drag. i did the rear also, adjusting them with slight drag. I took it for a drive, seemed ok, pedal was pretty hard and it took effort to stop, but i assumed it may need to break in again as i had them apart.
So this morning i took it to work, the brakes were really hard still,, they took time to stop, and the one wheel, the one that had the sticking cyl, sounded really "scronky" you know the sound that brakes make.
So i got home after work, and took the fronts apart again. No leaks, i scuffed the shoes up with sand paper, brake cleaned them and the drums, adjusted them so the almost spun freely and put them back together.
back the car out, forward and reverse, and the pedal felt the same, and it still made that "scronky" noise, dont know what is up, oh i have manual, 10x2.5 brakes
