ricomondo
NEW - Pack of (3) different Master cylinder gaskets ; 2) foam 1) gasket material - $6 made by Detroit Muscle Tech.
NEW - 69-74 brake distribution block part #BLK250 - $60
NEW - (rebuilt) by Brake/Equipment Warehouse in MN - Weatherhead brake distribution valve - $200
NEW - 72-76 A body Rear axle brake line brass T (no bolt) - $15
NEW - LARGE chrome master cyliner cover with bail wire - says "WARNING - clean filler cap before removing, use only DOT3 fluid from a sealed container" - $25
NEW- Power steering return hose/clamps - $10
***PM IF YOU NEED TO SEE CLOSE UP OF A PARTICULAR PART - THANKS****
Prices don't include the ride -
Located in NW/Indiana
PM here on the board!
