brake question 2001 dakota
VDART
Shulte Ks
I have to replace at least the rotors on my 2001 Dakota(warped). Are the so called premium brake rotors worth the cost over oem style?
I have at least 2 options below from the same seller, they also list a ceramic pad
Ebay has tons of options all with good feed back.
I'm a moderate driver & do not tow-- I do not want squeaky brakes when this is done & I don't want to do it 30 days down the road , plus Kansas is pretty flat & less populated than you east/west coasters
http://cgi.ebay.com/ebaymotors/ws/e...0745431159&viewitem=&sspagename=STRK:MEWAX:IT
http://cgi.ebay.com/ebaymotors/ws/e...0739107526&viewitem=&sspagename=STRK:MEWAX:IT
thanks guys/gals--
Lawrence
I just put the OEM style on my wifes Dakota. Drilled and sloted not worth the money to me.
check rear brakes for correct adjustment,also check wheel cylinders they can rust up on inside,causeing rear brakes not to work,causeing front brakes to over heat and warp rotors
Don't bother with drilled and slotted. They do little if anything in real world driving and can't be turned.
I just did a full brake job on my 99 Dakota. Got everything at NAPA and the brakes work great.
