[SOLD] Brake rotors, torsion bars, center link
hotrod426
michigan
Doing some spring cleaning and these are in the way and need to go. These are all from a 76 slant 6 duster, the car had just under 65k mi. The center link has light pitting on the ends and is powder coated black, the torsion bars are slant 6 .990 dia. one has some light pitting and are painted black, rotors are for a large spindle thickness is .990 and .995 can be turned to .940 and are 11 in. dia. both have light surface rust. These parts are located in grand rapids mi. $75.00 takes everything.
Are the bars slant six bars or are the .990 bars? If they're truly .990 I'll take em
The car they came out of was a slant six car and there is 990 on the end if you can give me a day or two and i will check with a micrometer and get back to you
Thanks, that'd be great. If they're .990" I'll definitely take em. If the numbers on the end actually say 890 then they're slant bars
