Brake spring
jfrydaddyo
Member
Ok
Hello I am rebuilding a 1967 barracuda fastback. Does an automatic brake pedal have a spring? If so where does it attach? And is there a part number? I ask because I have put in all new lines and a wildwood master cylinder (manual brakes) when I let up on the pedal it bounces a little because of the master cylinder pressure. Thank you for any info
