Brake swap question?
Ohio Ironhead
Middletown, Ohio
I need to know if the typical 73 up disc brake swap will work on a 66 dart. I've always heard it will work on 67 and up but it looks like a 66 dart is coming my way and I want to see what I'm looking at for the disc brake swap.
yes sir brother...the 73-76 upper control arms and spindles will work no problem on any 63-72 A-body drum brake car. Make sure you also use the prop valve of the donor car, and if the donor car has a front sway bar it will not work on the 66. The 63-66 cars are a tad narrower, so I would suggest you sell that along with the lower control arms and keep the ones on the 66.
