Brakes suck ace
Dusty74
Active Member
Glendale, Az
It feels like I have no power brakes I have to really push on them for the car to stop...What would be some things I have to look at? I'v checked the brake fluid and it is blackkk...How do I bleed them
Ok i'll check those out...Would the brake light come on if a certain thing happens or just whatever?
that is usually from a failed caliper, hose or cylinder causing the diverter to isolate the front or rear. If you have brakes but just a stiff pedal and pumping doesn't help its a vacuum or booster issue most likely.
Hmm well I can feel a little difference when the car is on...further investigation is needed!
