broadcast sheet help
plumdart69
Ontario,Canada
i recently found out that my broadcast sheet that i had found for my 1969 dart swinger is not the right one for my car.i had someone tell me that i can get the info off the internet for the broadcast sheet,to find out what the dart came with orginally.no luck as of yet in finding anything.does any one have any ideas where i can find out this info.there is no fender tag as well.i would like to get both of these.any help would be great!!!.thanks
Here you go: http://www.chryslerheritage.com/pg904.htm good luck now!
http://www.mymopar.com/tools.htm
on the right hand side you'll find a link for code sheets. Becareful, I found the correct sheet for my 73 swinger and there were some changes done to the car before I bought it. the build sheet says my paint code is F3 well there are two seperate layers of F1 there, so it had to be painted twice. It also says there was a full vinyl top but there is no top there now. There is Rallye wheels there now but the build sheet says full hub caps.
