Brodix heads
I have a set that will end up on my car if I chose to go with a small block. Was told by several shops that for a n/a street motor they are not a good idea but with boost they will work fine. If I go with a small block it will be a twin turbo car, so they should work just fine....I can say that right out of the box they are in need of some serious clean up around the valve seats and stuff.....
Well i was hoping someone could tell me what header they used on there car. It is killer trying to find that answer
it's a raised exhaust flange, you can hack some headers up/lengthen them to work.
Those heads are good, if anything would make them not streetable , it would be too much port volume.
At 195cc's those heads aren't too big for a hot sb street motor, they are aimed at a higher rpm range, sure, but on a stroker...look out!
yea, its 422ci and made just under 700 on dyno. I would say they flow
well enough. Add that to a 2850lb duster with a 300 shot of gas and i would say we have a rocket!!!!
