Small Block Cam Dynamics Solid Flat Tappet Camshaft
For sale is a Cam Dynamics mechanical flat tappet camshaft from my 360 ci bracket motor. The specs are 0.585 lift with 310 degrees advertised duration and 275 degrees duration at 0.050 lift on both Intake and exhaust. This was used for 50 runs and ran a best of 10.48 in my W2 headed 360 ci Dart. The cam comes with the matching solid lifters matched to each cam lobe. Always run with Kendall 20W50 racing oil. Cam and lifters are in good shape. See attached cam card for the full specifications.
Price is $200 shipped to lower 48 states.
