HotrodColt
Yep, another topic that’s been beat to death but I can’t find much in the way of a combination using the parts that I have. I have a 318 that was pulled from a 74 motorhome, however, after running the numbers on it, it’s a 68 engine with forged crank, 340 rods. Appears to measure to a stock bore size, can still see the cross hatch in the bores and there’s no ridge. It has the closed chamber 234 heads from a 273. I want to put this engine back together with a few modifications. I’m going to run an edelbrock 340 single plane intake, but I’d like to know which cam I should pair with these heads. Most I’m going to do to the heads is port work, keeping stock valves, May upgrade the springs depending on the cam. I was looking at the Hughes whiplash but it says not to run over 8.9cr and my understanding is that these heads put it at 9.1cr. Also thought about the comp Thumpr. Keeping stock converter, gears are negotiable.
