Cannot match rear brake hose
jim ayers
fastback fish guy
Grovetown, GA
I am trying to finish my 69 barracuda. Rear hose appears original as does the bracket which is attached to the body supports the end of the hose. My original bracket is indexed for a hex ended hose. All of the parts stores list a hose without a hex end. Any suggestions? See photo with original and repro hose
Fine Lines carries the hose with the junction block and without.
Give them a try.
You can use the one with the junction block included if you remove your seperate one from the axle.
Or use the one without to retain originality.
Any decent sized hose company can make a hydrolic line while you wait. Alot Mom and Pop parts store can do it as well, but does not have a large selection as a larger company does. Here in charleston, sc, we have Charleston Hose and Gasket. Whether a line brakes on my forklift, bridge saw, or even my 61 Caddy...they wake it up while I wait. Hope you have a company like that around you.
