[SOLD] Carb 1972 Dart 318 BBD Carter
Pabuhr
Iowa
I have a carburetor from a low mileage 1972 Dart. Includes the choke mechanism and attaching bolts. I was not able to test this unit, so buy it with the thought that it may need a kit installed. It looks very good and comes with the red limiter caps on the idle mixture screws.
Located in N.E. Iowa.
$50.00
If the base mounting is the same as a mid 70's 318 with a Holley I would be interested in this carb. Was this from an auto trans or is it a manual set up. I have a auto so need to make sure linkage is correct.
