Carb Accelerator Pump Discharge Nozzle WHAT SIZE
Dustedu2
Dixon
Here's some spec's on the engine. The Quick Fuel has a .035 or 36 Accelerator Pump Discharge Nozzle front and rear (can't see the number real well with out my glasses),
340/422ci - 4" stroker crank, Ross Flat top Piston 10.5:1 CR
Headers- TTI340A-C5
Comp Cam XR280R Solid Roller
Comp Pro Mag 1.5 Roller Rockers
AirGap intake with 750 Q-series Quick Fuel and 1" super sucker spacer
Stock Edelbrock Closed Chamber Heads (63cc)
3" TTI exhaust X pipe Dynomax Super Turbo mufflers
I have not driven yet but does anyone with experience have any suggestions on other squirters I should have on hand to try once the 3 feet of snow melts? :happy1:
You should also has some pump cams also,Tuning a Holley is not that hard trial and error.Go get your self a trick kit has jets,man tons of partsssss.
I will get a kit! Any other pointers? technique of tuning?
