carburetors 360 , 273
la2alle
Bad Fish 65
west palm beach
I went on this site a while back and ask what was the largest cfm 2v carb I could put on my 273 65 barracuda.It was suggested that i get a 2v from a 360 which i did.What i didnt know was that the bottom of the carb on the 360 is larger than the 273 2v.My question is do they make ,can i get
a base that will let me use this carburetor on my 273 manifold .t needs to go from small to large so i quess some sort of adapter is needed.Any help would be appreciated.
do you have A j.c. whitney catolog ???? they used to sell adapters,,
also try looking at jegs.com or summitracing .com type in carb adapter in the search box,, your locl speed shop should have a trans dapt catolog,,,they make things like that,,,do A google search on carb adapters or search transdapt,,,they are out there,,what year 273 ??if it is a 1966 or newer 273 you can use a 318 or 360 intake,,and wont need an adapter,,im sure some one on this site has a 318 2 bbl intake laying around,,,if the 273 is a 1964 or 65 the intakes wont interchange,,good luck
