[SOLD] Carter AVS 4612 D9
CL3406
BC
I have a Carter AVS 4612 for sale. D9 date code. Cleaned & rebuilt with carb kit, new pump check valve, new choke pull off, floats tested, 489 primary jets, 398 secondary jets, 16-160 step up rods, base gasket. $300 plus the ride. Thanks.
New price $250 plus the ride. Good price for this 4612, just bolt it on & set it up. I have built/repaired lots of these over the years & they all work great. Anyway I won't leave you high & dry after the sale if you require help with the set up. I am not assuming you don't know how by any means, just not everyone is a tech or mechanically inclined on this site. If I can help I will. If you require a video of the last one I built I can send that via text or whatever. Just PM me. Cheers!
