Cartool frame conn. w/ ebrake?
swing69
I’m just an old guy……
Central NJ
I'm thinking about purchasing the UScartool frame conn. for the 69 Dart. The ebrake cable (and floor guide) seems to be on the "inside" of the connector path. Meaning, how do you get the cable across the frame connector?
Also. what about brake lines and fuel lines crossing the connectors?
Picts would be great too. thanks!
Heres a pict of the drivers floor, from underneath. Notice the cable guide position.
I would call John Paceman at USCarTool he probery has pics since he test fitted them to cars before selling them.
I now that a guy called Crazypete on moparts.com tested the a body ones on his dart sport or it may have benn his A body cuda? been a long time since he did it.
I work at Us Car Tool we have tons of pics online. You do have to drill a hole for the e-brake, however there are notches for the fuel and brake lines to pass thru. if you're using stock brakes lines you will have to install a couple, I suggest adding a proportioning valve inplace, it's a good upgrade to an older system, any questions give us a call, we love to help...
How'd it work out with the E-brake? I just did my connectors and just have the ebrake disconnected for now. Any pics?
Also, I looked on the US Car Tool site and couldnt find any other pics of the EBrake. Can anyone else provide guidance/tips/experience/pics for this?
Thanks
