casting #
arh
i am trying to verify if the motor in my car is the original. 67 cuda, vin decoder says 273 4v. fender tag says it is a formula s. casting # is
2806030 273-2.
thanks,
adam
The VIN will be stamped only if it's a late build '67, the VIN stamping of the blocks and trans. officially started in the '68 model year.
Unfortunately you can not tell by the forging number on the block wether or not it's a 2bbl or 4bbl, that I'm aware of.
