[SOLD] Champion Radiator Driver's Side Inlet
RLF Cuda
Barracuda Bob
Aurora, CO
I am installing a 340 in my '68 'Cuda with Edelbrock heads. This forces me to use the newer aluminum water pump with passenger side inlet. My Champion radiator with the drive's side outlet no longer fits. I had this in my 'Cuda for about 1500 miles. It is like new condition. $200 3 rows and 3" thick
Also have the Champion 16" fan and shroud for $150.
You lose about 3/4 inch clearance with the aluminum water pump. It is a really tight fit with a thick aftermarket radiator. Be careful, don’t be me…..
I see. Hmm. I have the stock cast iron water pump.
I had better go measure, anyway.
May I ask the reason you went with an aluminum water pump?
