[Found!] Charcoal canister bracket for 74 Dart
weebull
north port fla.
Rating - 0%
0   0   0
I'm looking for the charcoal canister bracket for a 74 Dart. I think 72-76 are the same. Any condition is fine, the cheaper the better. If anyone is going to the Garlits show and can bring one that would be great. I'll be there Saturday looking for one. Thanks FABO.
Probably not. 77 would be an Aspen or Volare and they are different. It has to look like the one pictured.
3769052 is correct but the one you listed from Ebay has different mounting locations. The pictures aren't the same as mine. It has to be for an A body.
ok I was going by the listing and it says the two part numbers interchange, I didn`t think they did. Also the 77 volare takes a 3577596 so it is different from yours also
I have this one on a 74 Dart. PM headed your way.
Three canister brackets listed for abodies.
3671701 - 1972
3577594 - 1973 up to April of 73
3769052 after April of 73 thru 76
3769052 is what I'm after. It has to look like the one I have pictured. My car is a 74. Thanks for the info.
I have 3 from 1972 Dart Swinger. It took me 5 tries till I found a perfect one for me! The important thing to look at is the canister clamp. One has broken long bolt, another missing.
In CT
Looking again, the upper tabs on the 72 are offset where mine was straight across. The picture in my first post is wrong so I removed it. These are my mounting holes.
The 1972 is mounted to the radiator support
My photos show the screw (bolt) that holds the canister are damaged so pick the one you would want to fix
The mounting tabs on the 72 look different than a 74. Mine mounts to the inner fender like the photo on post #14.
