[WANTED] Chrysler 2204360 Speedometer Gear
RustyRatRod
Caput villa stultus
Georgia
Does anyone happen to have a 2204360 21 tooth speedometer gear? It's the small diameter gear for the early A. They are different than the 67 and up big style. I think it's grey in color. Thank you drive through.
I know I have one,just got to count the teeth. You may be in luck.
Get back to you late tomorrow.
Take a look in the Ford section of National Parts Depot. There are some on there that look like they are the same as the earlier speedometer gears.
Thanks for reminding me! I've looked at some of those before and thought they might work. I may order one and see.
I don't know man. They are very similar, but I don't know if the Ford gear will work or not. For $8.95, instead of Brewer's 65 bucks, I might try one.
Ford gear.
Mopar gear.
