Clutch Noise
nodemon
St.Louis
Here's a short video of a noise when clutch pedal is coming back up. What is it..?
Not in this vid, but there was a constant noise when pedal was depressed that seemed to get louder the longer depressed...and same type noise once pedal was up but in gear and moving...like clutch was slipping..? I adjusted clutch rod and that seemed to help the noise when pedal was depressed, but "slipping" noise remained. Can you adjust a clutch slip by the rod..?
Thanks for any input.
