[FOR SALE] Complete 383 and a833 trans
Nimrod
Member
Louisiana
Rating - 0%
0   0   0
I have a complete a833 setup for a b body. The trans has been rebuilt with a kit from brewers performance, has hurst shifter, hurst shift leaver, ram fly wheel, McLeod clutch and pressure plate 11", along with brewers z bar and adjuster. Everything about this trans is ready to go. It is currently in my 67 coronet and you can see it in working order. The only reason I'm selling is to upgrade to a 6 speed trans. The 383 big block is also for sale from the 750cfm edlebrock carb to moroso oil pan along with headers. The bottom end is a forged crank, reconditioned rods, forged pistons that bumped the compression to 10:1. Clevite 77 bearings were used with the crank being .020 and .010 rods. The top end is open chamber iron heads with a recent valve job and surfacing. The engine runs like a top
You are more than welcome to come see the vehicle run and that the trans works properly. The engine and trans have less than 1000 miles but I've decided to swap a genIII hemi and 6 speed trans for a more modern feel. Asking $3500
Awesome coronet! Can't go wrong with a 6 speed and hemi! Wish you the best on your build :thumbrig:
Can you pm me info on the A833? bearing retainer size and first gear ratio? And interest in selling it by itself? Thank you
