composition headgasket help
Joseph24251_200
The Mopar Kid
Fayetteville
I was about to install my heads but i have a set of composition headgaskets and wanted to know if it just like putting on regular headgaskets or not. Someone please reply.
Regular head gaskets are composition, do you mean MLS (multi layer steel) head gaskests? If you do my Mr. Gasket MLS head gaskets were supposed to be installed clean and dry so I did. You should follow the gasket manufacturers recommendation. MLS head gaskets will seep a little coolant at first but it will stop after a few heat cycles.
Chuck
