lgarbz Well-Known Member Joined Apr 16, 2009 Messages 134 Reaction score 3 Location Oregon Feb 2, 2014 #1 what's the correct backspacing for wheels on front disc brake set up and 8.25" rear end?
Woods74 Broke Senior Joined Aug 21, 2010 Messages 6,003 Reaction score 484 Location Seattle, WA Feb 3, 2014 #2 The same as the backspacing for a cop car reeeyum.
fishy68 Tyr Fryr's Inc. Joined Jan 11, 2005 Messages 16,584 Reaction score 1,264 Location Central, IL (Hooterville) Feb 3, 2014 #3 lgarbz said: what's the correct backspacing for wheels on front disc brake set up and 8.25" rear end? Click to expand... Not quite sure I understand your question. Are you saying your using front disc brake setup on a 8.25" rear??? If so I'd sure like to see how you did that.
RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member Joined Jun 7, 2010 Messages 104,898 Reaction score 102,527 Location Georgia Feb 3, 2014 #4 It is something you need to measure on every single car because none of them are the same.
72bluNblu FABO Gold Member FABO Gold Member Joined Nov 28, 2008 Messages 15,055 Reaction score 9,116 Location NorCal Feb 4, 2014 #5 What car? What size rim? What tires? The "right" backspace can be anywhere from 4" to 6.5" depending on the car, rim, and tire.
