4spdragtop
Hi all, currently redoing our 67 904 as well as installing a Transgo TF-2.
A couple questions and probably more to come.
Upon inspection of direct drum, there are witness marks that appear to be from the steel plates? But the plates are held below the witness marks with a snap ring.
Is this an issue? The steels are fine.
Now my Transgo TF2. The good thing ive discovered someone else has been in the valve body and already filed the groove/notch. As well as drilling 1/8" hole. So saved me some work.
I am at the mod where it states to grind down inboard land on the reverse servo piston. It specifically states this for 727, BUT no mention of the 904??
Ive seen a couple Boobtube videos that did it with 904's.
Thoughts?
Pics
Thanks
Steve
Thoughts?
Pics
Thanks
Steve
