crack
mp67dart
NW Florida
I noticed these cracks on the driver and passenger side inside and outside. They are were the A pillar meets the roof. Is this from to much body flex? If so can it be fixed with sub conn? thank for any help.
My 4dr has that same crack in that same spot, must be the weakest point. Subframe connectors will limit body flex.
I didnt now if it was common or not kinda had me worried.I drilled a small hole at the end of the crack and was going to weld it.
Sub FCs will help but I would cut out the existing sheet metal and sister in a piece a couple of gauges thicker.
Andrew
