[WANTED] crank and Power steering pulley
mopardemon340
WI
Rating - 0%
0   0   0
looking for a 2v belt crank pulley and a federal power steering pulley for a 340. also if you have a used pump bracket I could use that to. its a aluminum water pump.
72 demon.. I got a brakey for the PS but its missing 2 parts. do you know if I can use the 2 back brackets of a swag on a federal pump.. not the big main one but the 2 smaller trangel one on the back
still looking for a crank pulley.. who has one. is there a difference between the pump pulleys. ones that go with a 2 v belt crank pulley and single v belt crank pulley
I don't think you can use a Saginaw pump pulley on a Federal pump or vise versa. The crank pulley could be used with either pump. Also the power steering pumps had different diameter pulley's too. A single groove crank pulley would have only been used on a vehicle with manual steering car, and without P/Steering. You are using a factory aluminum waterpump or a cast iron one? The 72 year would be the aluminum one. We should have a very nice used one, 2 groove crank, but would need to look at the shop first. PM if you still need.
I have a Federal pump from my '65 273 that I'm trying to mount to a '69 340 with Moroso aluminum water pump. Need later bracket. Still have one?
Yes.... I have a 318 motor on a stand, w/power steering pump all mounted, that we can send you some pic's of w/ a cell number. You cannot post PHONE NUMBER"S on any threads, so " Start a Conversation with us, and we can text some pic's to you! Dodge33
