[FOR SALE] Crank and Rods to trade to good used small block cam and lifters
Garrett Ellison
Up in the holler…
Southwest VA
https://www.summitracing.com/parts/...MI7orj55316AIVPyqzAB00WQnNEAQYASABEgItmfD_BwEFor trade and split the shipping down the middle. Looking for a usable hydraulic flat tappet cam and lifters for a 10:1 360. Used Reman 318 cast truck crank in very good condition, STD. Mains .010 on the rods. Pistons will be removed from press fit rods.
Probably .450-.460 lift and up to 290 plus duration. Will probably be using some probably stock 308 heads and haven't gotten them yet to take the exhaust valve rotators off and see how much lift we can get before retainer to guide interference . But anything better than the improved stock replacement .405 lift 255 degree thunder stick we pulled out of the reman engine this rotating assembly came from, including a generic 340 replacement like a sealed power CS644R or CS1019R Melling SDP 22 or 23203.
