[SOLD] Crower Racing 68795 Roller Valve springs
Swingin1970
Santa Barbara CA
27 passes. Changed combo all springs checked good.
$250 Shipped
$540 New from summit.
284LBS at 2.00" installed
660LBS at .700" lift
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in): 1.560 in.
Coil Bind Height (in): 1.160 in.
Damper Spring Included: Yes
Spring Rate (lbs/in): 546 lbs./in.
Inside Diameter of Outer Spring (in): 1.145 in.
Inside Diameter of Inner Spring (in): 0.745 in.
Valve Spring Style: Standard
Valve Springs Coated: No
