I used the Fastlanewest dash insert and hated it so I cut the back out of a stock cluster, leaving enough material around the edge the glue in a flat sheet of carbon fiber and put the gauges in that. you could do the same using aluminum or sheet metal.
pictured is the Fastlanewest product before I replaced it. in this picture I have 3M di-loc carbon fiber-like shrink wrap on it.
unfortunately, it isn't reasonably priced even if the product was exceptional, which it wasn't.
