DionR
For Sale: Custom K-Frame for an 63-66 A-Body
Shipping from: Spokane, Washington, zip 99001
Price: $50 OBO plus shipping
Payment Methods Accepted: Paypal or Money Order
This is a late model k-frame that I sectioned to fit the frame rails of a early a-body, and then moved the motor mounts to match the motor location. I wanted a better idler arm arrangement, motor mounts and sway bar, so this is what I did. I've included links to threads I started when I was building it, just for some history.
Only issues is the passenger side motor mount could use a little more clearance, and the sway bar mounts on the lower control arms are off if you use stock arms with the mounts in the factory locations. I've had this bolted into the car for some time, and had a sway bar mounted with the factory mounts, but my plan was to grab some non-sway bar lower arms and weld new mounts to them in a new location.
Slant Six Forum, :: View topic - I want a through bolt idler arm on a '63 Valiant. Input?
Slant Six Forum, :: View topic - Thru bolt idler K-Frame, round 2
Slant Six Forum, :: View topic - Thru-bolt idler installed in a '63 Valiant
Car is long gone, time for this to go away, too.
