hotrod swinger
Has anybody done a custom gauge cluster for a 66 dart?
Did you replace the upper dash with flat sheet metal,or is it just covered?Work in progress, but you get the idea.
Yep. I patched up the vent holes and welded up the mounting holes for the pad.Did you replace the upper dash with flat sheet metal,or is it just covered?
