DAKOTA SPORT
Member
I am putting in a fast system and have removed the ecm which our dakota has ran 12.46@101 - it was modified while the truck was in california and has worked fine $200 till now 5.2 magnum - 904 trans - with a bluprinted and balanced nhra stock eliminator legal motor we also have:
8 1/4" mopar rear 4:56 gear set gears and instal. Kit $250
sb chrysler lakewood blowshield bell w/clutch fork - zbar & block saver plate $175
(1) moroso 89552 0-15 lb 4" tire pressure gauge nib - $120
(1) moroso mechanical tach - mounting bracket and cable
(1) older acd box (black)
(1) acd #7500 co2 bottle never used - $60
(1) msd # 8738 two step (2step)
(1) msd pro power coil (nib) - $100
(1) dedenbear tsc-4 throttle stop controller
(1) dedenbear dominator ts-5 (under the carb) 4 blade throttle stop - (primary & secondary) $300
(1) chuck nuyytten prepaired 1050 dominator ( that worked perfectly when running on the above throttle stop} - $700
(1) holley dominator 1050 spare carb also used with the above listed dedenbear ts - $600
upper/lower a-arm bushing set from moog for dakota and i believe aspen/volare
any questions don't be shy need to sell some of this stuff
