Mckibben
OK guys I have a dana 60 narrowed by Moser. The axle bearings are the disk brake type. I bought a set of bearings that bolt to the housing for drum brakes. Do the backing plates go on the housing and then slide the axles in and bolt on or do the backing plates go on the axle and then the bearings so it all slides in together?? Dont want to have to take bearings off because it wasnt done right the first time. Any help would be appreciated.
