Dart hood on a 70 Duster?
Bmsjax
Layton, UT
Would a 70 Dart hood fit a 70 Duster? I know the look different but would it fit? Mine needs replacement and hoods arnt easy to come by so I have found.
No you can't the only way to put that hood on is to swap the entire frontend. The best way is just to find a 70 to 72 duster hood
No fenders.
I have two or three hoods, two are OK the third is really nice but has holes for scoops.
Depending on which one you want anywhere from $40-100
PM me if you are coming through town again.
specific years of duster,valiant and scamp hoods will work for yours but not a dart hood.....2 different animals.
as mentioned before, to use a dart hood you would have to swap the hole dart front end over.....and that being the case you would have half way completed cloning your duster into a demon and you may aswell buy a demon tail panel and badges and finish the job lol.
good luck on the search.....the hoods pop up here on fabo all the time and if you keep an eye on Craigslist they pop up from time to time.
