[WANTED] DASH SWITCH BEZELS 1968 DART
DavidW
California,USA
Rating - 0%
0   0   0
Looking for switch bezels for the rheostat, head light, and washer. Also the knob on the washer and the knob for the headlight switch. I also need the bezel for the ignition switch. Thanks for any help.
I think I might have what you're looking for. Do they look the same as bezels that hold some of the antennae's in place? Threaded I.D.?
I'm not familiar with the look of the antenna bezel. The rheostat and washer bezels are the same; threaded with a larger center hole with the threads, and the head light bezel has the small center hole for the knob shaft. I found a acceptable ignition switch bezel; not perfect, but okay. I did some research and now believe the bezels and knobs are the same as the B body of '68. I'm going to call Classic Ind. and talk to them as they have those in stock. I'll keep you in mind. Thanks for your reply.
Found the HL bezel and wiper switch bezel, these are from 67-9 cudas.
1st pic hl bezel looks "rusty" but it's not.
