Deck Lid Nut Insert
mopowers
West Sacramento, CA
Does anyone know what applications use this particular deck lid hinge nut insert? It came off my 66 Dart and I noticed a crack in one of the threads, so I was going to place a wanted add. I'm curious what years and models use this particular piece?
They may have changed in 67 . But like you said ,just tack weld the crack, should be alright.
I have a trunk lid from an early Valiant that is otherwise worthless.....Call me, If it has the same style nut plate in it, I'll mail it to you.
Thank you Greg! Let me do a little more research to see what crosses over.
The nut plates slide into the hinge arm itself though, so unless you have those hinge arms I'm guessing the trunk lid you have probably doesn't have these pieces. Either way, I appreciate it!
