[FOR SALE] Demon hood and NOS dual snorkel scoop
69GT
Metro Detroit
For sale are a 72 Demon hood and an NOS 73-74 style dual snorkel scoop. I bought this for my 70 Dart but at least for the time being I have decided to sell it as I could use the money for parts for my 69 Dart project. The hood was a base Demon hood with the holes for the scoop added as well as holes for hood pins. The hood was pretty straight when I got it but it had several layers of paint on it so my paint guy suggested I have it media blasted (cost me $125) so it won't need to be blasted in the future. When I got it back from the blaster, it was no longer completely flat as they must have not blasted it the proper way. So now it has some very shallow impressions in it that correspond to the areas in between the support structure on the underside (I hope this makes sense). Anyway, my painter put on a coat of epoxy primer for the time being to keep it from rusting. So it does need some smoothing over with filler on the top side. Also, whoever drilled the holes for the scoop studs also made them oval shaped apparently to get the studs to all drop through the hood easier. This is unnoticeable when the scoop is in place. The scoop is NOS which I bought many years ago. It is the later style that has the rise in the center of the bottom to clear the center ridge of the later hoods. I was just going to have that filled in to match the flat hood but it could be installed without doing so. I am including a new can of body filler with hardener. I have the original studs for it but I don't have the original nuts. I am asking $900 o.b.o. If I don't sell it I will likely be finishing it and putting it on my 70 Dart next year which I would still like to do. Local pickup only and I will not sell the scoop separately.
