Apr 28, 2009 #1 7 71SCAMPY Banned Joined Apr 28, 2009 Messages 18 Reaction score 0 Location warren mi I Have A 71 Scamp I Also Have A 80 Newport I Was Told I Could Use The Newort Setup On The Scamp With Little Hassle Is This True? If Not Can Someone Point Me In The Right Direction Please.
Apr 28, 2009 #2 C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 20,303 Reaction score 8,450 Location 92201 You need big ball joint upper arms, disc prop valve and a disc master cylinder and you should be good.
Apr 28, 2009 #3 7 71SCAMPY Banned Joined Apr 28, 2009 Messages 18 Reaction score 0 Location warren mi So Will The Upper Control Arms From My Newport Work? I Hope So Man That Would Be Great
Apr 28, 2009 #4 65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 14,633 Reaction score 5,578 Location Strasburg, VA 71SCAMPY said: So Will The Upper Control Arms From My Newport Work? I Hope So Man That Would Be Great Click to expand... Nope - you need the 73-76 A Body large ball joint control arms
Apr 28, 2009 #5 7 71SCAMPY Banned Joined Apr 28, 2009 Messages 18 Reaction score 0 Location warren mi Ok Sounds Great Thanks Guys
