Disc Brake Conversion
demonguy71
Montrose, MN
I am wondering if anyone has used parts from a Mirada to convert to disc brakes on an A body, specifically 72 demon?
they should work. if I'm not mistaken the Mirada has the 11.75 rotors (which is a good thing). You will need 73-76 A body upper control arms for the large ball joint to fit into the spindle. Also get the 73-76 lower ball joint which is a bolt in swap, nothing special. There's a couple of threads here detailing the swap step for step. Just type what you are looking for in the "search" box near the upper right corner and happy hunting!
Google mopar action disc o tech. It's a real comprehensive article on what parts you will need to do the swap. I'm just finishing up a disc swap on my 72 Demon. Helped me out alot. Good luck!
