[SOLD] DISC Brake Proportioning Valves From The 71-76 A Body Cars
hemi71x
hemi71x
Rancho Cordova, CA
Up for sale are these disc brake proportioning valves for the A body line of cars. The valves that i have in stock are with the hard lines for Power Brake applications, and Manual brake applications. The difference is, the lines are longer, for the power brake cars.
Use the valve(s) on any year vehicle, that you might be doing a disc brake swap on, but this style valve was officially used on the 71 to 76 A body cars, before they started using a cast iron valve, sometime in 76.
Whatever one that need, want, i can set you up with either set of hard brake lines.
Just tell me which one that your after.
$70.00 for the valve with the hard lines, or i can sell just a valve for that price also. The reason for that is because i don't get these assemblies for free at the wrecking yards when i find them They nickel and dime you to death for every little item, and they charge you for the lines that are attatched to the valve. So these parts cost me more money, than just a bare valve, so i have to pass along the cost, or it's just not worth it to sell these things. Still lots cheaper than those China repop ones that don't work, or leak all the time from reports that i have read, about these valves, from aftermarket sellers, vendors.
$70.00 for a valve with all the hard lines, or also the same for just a bare valve. Whatever you want to do. The mailing for just a valve, will be $7.25 by the mailman, and a valve with lines will naturally be a lot more, in a much bigger package, due to all the hard lines. + FEDEX, or mailing fees, + the cost of the box i will need to buy, + 3% Pay Pal fee.
Send me a pm, if your interested, and then we can go from there.
Jim V.
UPDATE:
The valve with the hard lines for POWER Brakes has SOLD.
UPDATE:
I now only have a prop valve with the hard lines for MANUAL BRAKE applications.
The other one has SOLD.
