[SOLD] Disc brake swap stuff...large bolt pattern
Jimacuda
Legandary Member
Legendary Member
Phoenix AZ
Yes, I have another 10.9"(approx.) disc-brake set-up from an F body (Aspen/Volare) available, bolts right up to a 67-76 A body (using either large ball joint upper control arms or DoctorDiff ball joint adapters).
May also fit earlier A's.
Includes: spindles, dust shields, good rotors, caliper brackets, slider type calipers.
Everything was removed from a working brake system. Calipers are good but included as cores for exchange.
It includes everything pictured. What you see is what you'll get.
$170 plus shipping. (approx. 100 lbs.)
Fits in 3 USPS large flat rate boxes for $64.50 insured to most US address.
Local pick-up in Phoenix, AZ.
Thanks FABO!:thumbsup:
(for replacement calipers, rotors and pads use 1980 Volare wagon w/318...better bleeder location)
(lower ball joint- pick any 73-76 A body, disc/drum same bj)
(lower ball joint- pick any 73-76 A body, disc/drum same bj)View attachment 1715090722 View attachment 1715090724
Do the calipers mount in front or back of rotor. Gonna mount a sway bar.
Mount them either way, front or rear.
Just swap spindles side to side.
You can mount em facing to the rear, but then you can have hose routing issues. If you mount em to the front then disc brake 73-76 A body brake hoses fit like they are supposed to.
FMJ calipers are a great upgrade too. The A body caliper pistons are 2.60". M body, not sure about F or J, but M body uses 2.75" pistons in their calipers thats made of phenolic plastic. I was able to buy plated steel replacement pistons made by allied signal on closeout from rockauto to reload my M body calipers
This is a screaming deal for the price guys. If i didnt have all my parts for both cars, i woulda jumped on this great deal. Not trying to steal your ssle thread, Just wanted to give another heads up on why the M body calipers make a good upgrade.
Sold?
Jake
