Dustert73
Stripping bolts since ‘10
Hey everyone,
I have a matched pair of upper control arms from a 73 duster with disc brakes. These look to be in restorable condition and are not bent or damaged from what I can see.
Bushings need to be replaced, the ball joints feel tight but I would still replace them too. Threads are fine but need to be cleaned up, both cotter pins broke off inside of ball joint studs so you would have to drill or nock them out if reusing ball joints.
100$ shipped to anywhere in the U.S.
or
85$ local pickup
Located in Granville, Ohio 43023.
or
85$ local pickup
