Door handle help
clhyer
Hopefully someone has disassembled their door handle recently, or took better notes/pics than I did...
I removed the door handles when I was doing the paint and body work. During assembly, there are three seals in the package. Two seals are used between the handle and the outer body. There is a small plastic seal/washer that goes somewhere, but where? I have a dirty one that I removed from the assembly, and I have a new one in the package to replace it, but where does it go?
Thanks,
C
Mine only had the two rubber molded seals that rest against the handle where it sits on the door. I assume the other one must go on either the front or rear stud?Maybe behind one the studs to keep moisture out?
