door hinge rollers
Fishercuda
Richmond, VA
I did a little digging in the forums and haven't found any conclusive information so I'm hoping a fresh inquiry might lead to an answer.
I've got a 65 Barracuda with a broken hinge roller (detent door hinges); the rest of the door hinge is in great condition. The driver side is always a struggle to keep open or close because it doesn't hang right without the roller. I've found a replacement set for GM (https://www.amazon.com/dp/B00GV8X31I/?tag=fabo03-20), but no luck on anything mopar.
Could anyone give some insight on whether or not these will fit or a different solution?
Cheers!
This is someone here who rebuilds hinges but I don't remember his name at the moment. Try a door hinge rebuild search here
member "res1vw21". He rebuilt a set for me and I'm happy with the result.
