Sep 4, 2014 #1 J jdsduster Well-Known Member Joined Aug 5, 2011 Messages 1,433 Reaction score 330 Location indiana the backing plate wont fall inside the jamb if i take bolt out will it?the rubber is gone that cushions the sleeve and i want to address it.
Sep 4, 2014 #2 momoparman MOISMYHOME Joined May 31, 2008 Messages 3,085 Reaction score 422 Location M I Z Z O U Should not as there is a retaining flange welded to the frame that holds the square nut. Now if it was broken or rusted then you may be taking off your door panels. Good luck.
Sep 4, 2014 #3 J jdsduster Well-Known Member Joined Aug 5, 2011 Messages 1,433 Reaction score 330 Location indiana got ya,thanks
