Door is the same but the glass is a little different I beleve because of the side inpact bracing. It would work but you would also need to use the trim and wetherstrip from the Scamp too. Also the inside of the doors are different. The 74's will have a full langth plastic door panel and the 72's will have the vinel ones and the door handle will be in a different spot. They will interchange but are not quite the same.
