[FOR SALE] Door window regulators
moparmarks
zippindippintie
Western Colorado
Good door glass regulators.
Good working condition
45.00 ea or 80.00 pr.
Plus shipping
Free delivery to the Fall Fling in LA with pre-paid.
I also have a lot of the other door parts. Channels and hardware.
Would you happen to have the posts that bolt to the doors?
Ok I checked the FPM's.
69-72
Dart 2 and 4 door and Vert
Valiant 2 and 4 door
Barracuda H/T, FB and Vert
All take the same 2765792-3
71-2 Dart and Duster FB
3454544-5
So all are the same except FB.
67-8 H/T 2 and 4 door and Vert all take
2583064-5
73 and up are different except 4 door takes the 2765792-3
73 H/T is a one year thing. 74 is different.
Now I need to figure out which are which of what I have. Some have a bigger spring so thinking those are for FB. I'll see if I can find any part numbers.
69-72
3454544-5
2583064-5
Good to know, I grabbed the regulators out of the front doors of a 74 dart more door I was junking as spares. They looked the same
I'm looking into this. My crash parts book says yes they are the same but as Mat's book shows they are not.
All my FPM are at the shop and need to look at those. Can't find any part numbers on the regulators.
I think I have some loaded Duster doors that I need to dig out of the pile.
I helped a buddy with a 73 duster. If I remember correctly the regulator assembly had 3 arms each tipped with a roller because these windows dont have a vent window division post to allow the window to ride up and down squarely. This is also the reason the regulator changed on 2 door hardtop darts and scamps in 1973. They did away with the vent window and division post that year. The 4 door hardtop kept the vent glass and division post through probably 1976, using the same 2 door hardtop regulator from 67.
Okay found out that most of these are actually 66-70 B regulators. Makes since, I've parted out a lot of those. Anywho the A and B regulator are very similar and have the same bolt pattern. main difference is the arm on the A is a little longer and they have a heavier spring. Could probably interchange.
So that being said I've sold a few A regulators and only have a few left.
The rest I'll post over on FBBO.
F/B regulators are the scissor type and different than H/T and Sedan.
